Designed for a variety of rooftop applications, the CADDY PYRAMID RPS H-Frame Series provides support for pipe, conduit, ductwork, cable tray, or any combination of these
Designed for a variety of rooftop applications, the CADDY PYRAMID RPS H-Frame Series provides support for pipe, conduit, ductwork, cable tray, or any combination of these without causing damage to the rooftop membrane. According to the company, the design of the base helps to uniformly distribute load and the continuous bottom surface mitigates unwanted stress concentrations. The base is made from recycled, UV-stabilized engineered thermoplastic while a foam pad provides a gentle interface for all roof types.
