Designed for low-voltage retrofit applications, LV1X single-gang mounting brackets feature extra-long screws
Designed for low-voltage retrofit applications, LV1X single-gang mounting brackets feature extra-long screws, which allows them to be used with up to 5/8-in. double drywall or wall thickness up to 1½-in. Wall plates mount flush to the wall, while mounting wing screws hold the brackets securely against the wall. In addition, the products can be mounted vertically or horizontally.
