Packaged in a 35-mm-wide DIN-rail enclosure, the VTD Series senses voltage in a wide variety of DC-powered installations
Packaged in a 35-mm-wide DIN-rail enclosure, the VTD Series senses voltage in a wide variety of DC-powered installations, including industrial motors, battery chargers, photovoltaic arrays, and wind generators. The voltage transducers can be used on circuits from 0VDC to 15VDC and 0VDC to 60VDC. In addition, fully isolated and industry-standard 4mA to 20mA loop-powered output makes use with existing controllers, data loggers, and SCADA equipment easy and reliable. Input and output circuitry also are fully isolated for enhanced operational safety.
