Designed for photovoltaic (PV) applications, these direct operating disconnect switches are available in 40A, 80A, and 125A models
Designed for photovoltaic (PV) applications, these direct operating disconnect switches are available in 40A, 80A, and 125A models. DIN-rail mounted, the disconnect switches feature an integrated pad-lockable mechanism as well as a shaft extension and rotating handle that can be ordered separately. In addition, the product is UL508, UL98, and KEMA certified.
