Roof equipment mounting system
Sept. 14, 2011
Designed as a companion for rooftop equipment, the Roof Equipment Access and Connection Hub (REACH) system provides a stable mounting system for electrical and refrigeration ancillary components and connections
Designed as a companion for rooftop equipment, the Roof Equipment Access and Connection Hub (REACH) system provides a stable mounting system for electrical and refrigeration ancillary components and connections, such as GFI, disconnects, and motor starters. Suitable for new or retrofit applications, the system uses industry-standard weatherproof connectors for all types of conduit, tubing, and cable for rooftop installations. According to the company, the product attaches securely to a building's rafters and consists of two rails that can each support up to 900 lb.
Reach Manufacturing
For more information, visit http://reachmfg.net/index.html.
