Step-up auto transformers
Oct. 3, 2011
ATX step-up auto transformers increase line voltages for indoor/outdoor lighting applications
ATX step-up auto transformers increase line voltages for indoor/outdoor lighting applications, facilitating use of lower voltage to LED drivers, ballasts, and other luminaire components, at needed higher voltage levels. Suitable for use with LED, linear fluorescent (T5, T5O, T8, and T12), and HID light sources, two models are available to step up 120V to 277V, each with different volt-amp ratings. In addition, the compact, square-shaped products are insulation-rated to 130°C Class B and are UL-recognized.
Thomas Research Products
For more information, visit www.thomasresearchproducts.com.
