Insulated lugs
Sept. 13, 2011
Color-Keyed insulated lugs eliminate the need for tape, heat-shrink, or cold-shrink insulation after installation
Color-Keyed insulated lugs eliminate the need for tape, heat-shrink, or cold-shrink insulation after installation, according to the company. Available in one- and two-hole designs, custom options include finish, tongue width and angle, and bolt size and spacing. The UL-listed lugs also feature translucent nylon sleeves that are pre-positioned. Made of seamless copper tubing with tin electroplating, the products feature a maximum temperature rating of 105°C.
Thomas & Betts
For more information, visit www.tnb.com.
