The CyTime SER-3200 sequence of events recorder (SER) provides time-stamped event reporting for 32 high-speed digital input channels
The CyTime SER-3200 sequence of events recorder (SER) provides time-stamped event reporting for 32 high-speed digital input channels. Designed to record the date and time associated with input state changes, time synchronization is achieved via unmodulated IRIG-B input from a GPS receiver or via RS-485 signal from another SER-3200 serving as time sync master. Data is available over an Ethernet network using a standard Web browser or via application software using Modbus TCP/IP.
