Sine Wave Nexus Promo 5f6a0aba9cb0d
Motor Protection Filter
Sept. 22, 2020
Product increases motor life and eliminates motor failure due to bearing currents
MTE Corp.’s SineWave Nexus combines the performance of a sinewave filter and isolation transformer with the company’s common mode protection technology into a single, compact design. The filter helps eliminate high frequency content and voltage peaks to extend system efficiency and motor life at any cable length. In addition, the product reduces common-mode and differential-mode voltages and currents because it cleans the PWM waveforms generated by VFD and virtually eliminates damaging common mode voltages that cause motor bearing failures.
For more information, visit www.mtecorp.com.
