The wire retrieval and protection system (W.R.A.P.S.) for rough-in construction is designed for the low voltage industry, to allow simple recovery of wire from plaster rings and protect wires and connectors inside the walls from being damaged by a drywall cutting tool or from being crushed between the stud and drywall. The protection device also keeps plaster rings clean from mud, paint, and debris. This allows connectors to be installed and wires to be tested at the rough-in stage.
MTM Industries
For more information, visit www.lvwraps.com.
Latest from Product Sourcing & Supply
