MotiFlex e100 Ethernet-compatible 3-phase AC motor drives can be used in both centralized control and distributed “intelligent drive” scenarios
MotiFlex e100 Ethernet-compatible 3-phase AC motor drives can be used in both centralized control and distributed “intelligent drive” scenarios. The initial launch of MotiFlex e100 provides drives rated for output powers up to 16A, in five steps of 1.5A, 3A, 6A, 10.5A and 16 A. According to the company, a selection of higher power versions will follow in 2007. Compatible with the Ethernet Powerlink protocol, each drive features an Ethernet hub, enabling systems to be built using a simple daisy-chain connection scheme.
