ArcCalc arc flash calculator software allows users to estimate incident energy level can categorize arch flash hazards at any point in a system. The software determines the arc fault clearing time for the protective device settings; calculates incident energy and flash boundary; documents PPE requirements; and prints custom warning labels, energized work permits, and diagrams with input data and calculation results. It uses generous tolerances for utility, transformer, cable, and motor data to calculate conservative minimum and maximum fault currents. It includes a validated library of protective device trip characteristics to provide accurate trip times for the calculations.
SKM Systems Analysis
For more information, visit www.skm.com.
Continue Reading
Continue Reading
Latest from Product Sourcing & Supply
