Clamp meter
Oct. 22, 2007
According to the company, the 3291 digital clamp-on hi-tester is the industry’s first flip clamp.
According to the company, the 3291 digital clamp-on hi-tester is the industry’s first flip clamp. Cat. III 600V safe, the pocket-sized clamp measures conductors up to 30 mm in diameter with a low-profile sensor core that is 8-mm thick. The device can be clamped in place to measure circuit breakers and other conductors as long as there is 12.5 mm of space between wires. In addition, the flip-down display rotates to a maximum of 180°, allowing readings at any angle.
Hioki USA
For more information, visit www.hiokiusa.com.
