Lighting control device
Dec. 10, 2006
The ELCU-100 emergency lighting control unit is designed for energy savings when used to control devices such as occupancy sensors and time scheduled systems by having these devices control emergency lighting in tandem with non-emergency lighting. These control devices can also enhance response from the emergency lighting, because they provide control at the branch circuit level and will force emergency lighting on even if normal power is interrupted in only part of the building. They feature wiring options to accommodate different control needs and an input for remote control
The ELCU-100 emergency lighting control unit is designed for energy savings when used to control devices such as occupancy sensors and time scheduled systems by having these devices control emergency lighting in tandem with non-emergency lighting. These control devices can also enhance response from the emergency lighting, because they provide control at the branch circuit level and will force emergency lighting on even if normal power is interrupted in only part of the building. They feature wiring options to accommodate different control needs and an input for remote control.
Watt Stopper/Legrand
For more information, visit www.wattstopper.com.
