Test meter
The Split-Jaw Smart-Meter is a voltage, continuity, resistance, and current tester combined with the capabilities of a clamp meter. The meter has automatic testing capabilities, which eliminates the need for a function dial. It provides volt, amp, and ohm measurements and performs AC testing as high as 200A without breaking the circuit, resistance testing to 2,000 ohms, AC voltage testing as high as 750VAC, and DC voltage testing as high as 1,000VDC. The meter has a rigid open jaw for hard-to-reach cable bundles, a low-battery indicator, and a push-button data hold function.
Ideal Industries
For more information, visit www.idealindustries.com.
Latest from Product Sourcing & Supply
