The AEGIS SGR conductive microfiber shaft grounding brush is designed to improve the reliability of HVAC/R systems by protecting bearings from electrical damage for the life of the motor. Targeted for use by OEM motor and fan manufacturers, repair shops, HVAC service contractors, and in-house maintenance departments, the device can prevent bearing noise, costly motor repairs, and downtime. No machining is required to install the device, and its conductive microfibers work with very little friction. Standard models of this device can fit AC motors ranging from 1 hp to 1,500 hp with shaft diameters from 0.311 in. to 6.020 in. Larger sizes are available for shafts with diameters greater than 6 in.
Electro Static Technology
For more information, visit www.est-aegis.com.
