Manufactured from electrolytic copper, the Eritech Hammerlock grounding connector joins the grounding conductor to the ground rod with the strike of a hammer. The connection is highly conductive and designed to withstand fault currents and lightning transients. The connector is now available in a two-hole model for 6 AWG and 4 AEG solid, and a larger version of the single-hole that permits 2/0 stranded wire to be joined to 0.625-in. and 0.75-in. ground rods.
Erico
For more information, visit www.erico.com.
Latest from Product Sourcing & Supply
Members Only Content
