This UV-rated rooftop pipe support has a 4-in. x 5-in. footprint and weighs less than 1/3 lb. Its sled-design distributes the load evenly, protects the roof membrane, and holds three ½-in., two ¾-in., or one 1-in. pipes or conduit. The support can be bonded to the roof or float with pipe expansion and contraction, and an integral pipe-clamping mechanism ratchets down to securely clamp pipes or can be set for loose guiding to accommodate for thermal changes. They’re available in 4-in. and 6-in. high models.
Erico
For more information, visit www.erico.com.
Continue Reading
Continue Reading
Latest from Product Sourcing & Supply
