AFC Cable Systems’ portable Pack N’ Roll cable dispenser makes installations easier by keeping cable clean and organized during transport. With the Pack N’ Roll system, pulling cable is quick and easy and prevents tangles and excess scrap during installation. To set up, the coil should first be placed inside of the dispenser. Next, the cable ties are cut, and the end of the cable is fed through the side opening. Once the desired length is pulled through the opening, the cable can be cut. When finished with the installation, rotate the remaining coil to pull the cable end back inside and put the lid on the dispenser. According to the company, the product fits commonly used sizes of Type AC and Type MC cables as well as NM cable.
For more information, visit www.afcweb.com.
