The Sector ballast and lighting control system combines occupancy sensing, daylight harvesting, and dimming control in a single integrated system
The Sector ballast and lighting control system combines occupancy sensing, daylight harvesting, and dimming control in a single integrated system. This topology-free system uses the same wiring type for all components and accessories. In addition, all components are on a single bus, with accessories connected to the network, not the ballast. Set up, reconfiguration, and maintenance are accomplished via central graphical point-and-click/drag-and-drop software control.
