Arc fault diagnostic tool
Oct. 12, 2009
Designed for used with any circuit breaker, Intelli-Arc is a hand-held diagnostic tool that helps end-users accurately determine the circuit in which an arc fault has occurred.
Designed for use with any circuit breaker, Intelli-Arc is a hand-held diagnostic tool that helps end-users accurately determine the circuit in which an arc fault has occurred. The tool features three sets of LED indicators that provide information regarding current, ground fault level, and arc fault level. In addition, the product can wirelessly transmit up to 250 ft with no barriers between it and the base unit.
Siemens
For more information, visit http://www.usa.siemens.com/intelliarc.
