Cat® C18 generator set fills a void without consuming space
With the extension of the Cat C18 generator set range, Caterpillar effectively fills a void felt by many who need a durable, reliable and more-than-ample source of backup power, but want to dedicate as little space to it as possible. The C18 generator set provides up to 750 kW and does so within the confines of its roughly 14' x 6' dimensions.
Of course, there’s much more to the story behind the C18 generator set than its compact size. Most notably, the story revolves around the engine that powers it. A longtime standard bearer at Caterpillar, this engine has performed around the world in multiple applications and in every form of harsh conditions imaginable.
In addition, the engineering of the C18 generator set is being recognized for its focus on those who will ultimately own and operate the equipment. This powerhouse was designed to do more than a job. It was designed to build confidence in the people responsible for its specification, installation and management daily. As a result, the C18 generator set was built to provide a flawless user experience.
It begins with a number of customer-centered engineering features, including a state-of-the-art control panel that enables users to monitor performance from remote locations. In addition, the integrated voltage regulator delivers both improved load acceptance and overall performance. Advanced Cat generators are built for an extended, dependable life and uncompromising peace of mind. These examples not only indicate Caterpillar’s commitment to forward-thinking engineering, but also its commitment to its customers.
Caterpillar strives to provide solutions that work. The C18 generator set is the latest example of delivering on that promise.
To learn more, please visit cat.com/c18.
Sponsored by:
