Square D circuit breaker
Schneider Electric Recalls Square D-Brand F and K Frame Circuit Breakers Due to Fire Hazard
March 20, 2014
Consumers should stop using this product unless otherwise instructed. It is illegal to resell or attempt to resell a recalled consumer product.
Schneider Electric has issued a recall of its Square D-Brand F and K Frame circuit breakers due to a fire hazard. Specifically, this recall involves Square D brand models FA, FH, FI and FY one-, two- and three-pole circuit breakers rated 15 to 100 amps, and model KI two- and three-pole circuit breakers rated 110 to 250 amps. The F model breakers were manufactured May 8, 2013, through June 10, 2013 and have date codes 13193 through 13241.
The K models were manufactured May 2, 2013 through June 21, 2013 and have date codes 13184 through 13255. The date codes are YYWWD format (example: 13184 = year 2013, week 18, day of the work week 4/ Thursday). The circuit breakers have a yellow label with the words “Square D” or the Square D logo. Model information can be found on the faceplate.
No incidents or injuries have been reported, but consumers should immediately check to see if they have the recalled circuit breakers. Consumers with uninstalled products will receive a replacement. Installed products will be replaced at no charge to the customer with an allowance of up to $300 per site to cover labor costs.
The breakers were sold through authorized Schneider Electric distributors nationwide such as Border States Electric Supply, Crescent Electric Supply Co., Dealers Electric Supply Co., Graybar Electric Co., Rexel, W.W. Grainger from May 2013 to June 2013 for between $200 and $9,260.
