Trespassers Beware!
Stephen M. Daniels, owner of Stephen M. Daniels Electrical Contractors of Lancaster, Pa., was kind enough to share this photo with us. “I was doing a service call for a dead circuit (forgive the pun), and took the panel cover off,” said Daniels. “There were missing knockouts, which is how the furry panel guest got in. This is another reason why the Code calls for no open KO in panels or boxes.”I could not agree more. Installing knockout seals is important for many reasons, including keeping trespassers out of the enclosure. Section 110.12(A) makes it clear that unused openings (except mounting holes and other openings such as drainage holes and air vents that are intended for the operation of the equipment) must be closed in a manner that provides protection substantially equivalent to the wall of the enclosure. Sealing up the unused openings also helps keep arcs and sparks from escaping (and possibly igniting) nearby combustible materials. Debris and liquids can also fall into unsealed and unused openings, causing damage to internal parts of the equipment. While the Code rules will not always prevent every critter from finding a way into enclosures, they will help minimize the possibility.
