Photo 223093105 © Ahmet Yamak | Dreamstime.com
Based on the 2023 NEC.
Question: Fill in the blank. A ground ring shall be installed not less than _____ below the surface of the earth.
See answer below.
Answer: 30 in.
Explanation: Per Sec. 250.53 (F): "The ground ring shall be installed not less than 30 in. below the surface of the earth."
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
