Photo 13840572 © Luis Alvarenga | Dreamstime.com
6671d14f9510739b16b251ad Dreamstime Xxl 13840572
Code Quiz: Ground Rod Requirements
June 20, 2024
Based on the 2023 NEC.
Question: If multiple ground rods are required, what is the minimum distance required between rods?
See answer below.
Answer: 6 ft
Explanation: As stated in Sec. 250.53(A)(3), "If multiple rod, pipe, or plate electrodes are installed to meet the requirements of this section, they shall not be less than 6 ft apart."
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
