© Travelling-light | Dreamstime.com
Dreamstime Xxl 25647751 6526f5b4273e9
Code Quiz: Equipment Grounding Conductor Requirements
Oct. 19, 2023
Based on the 2023 NEC.
Question: A 2-gang plastic box contains a light switch on a 15A circuit and a receptacle on a 20A circuit, and both circuits are wired with NM cable. Do all the equipment grounding conductors of both circuits need to be connected together, or is it permissible to have two separate equipment grounding connections (one for each circuit)?
See answer below.
Answer: All equipment grounding conductors of both circuits need to be connected together.
Explanation: Section 250.148(A) was revised to require all equipment grounding conductors to be spliced together even if they are for different circuits.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 219971504 © Julie Feinstein | Dreamstime.com
dreamstime_xl_219971504
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
