© Abhijitg | Dreamstime.com
Code Quiz: Stainless Steel Flexible Metal Conduit Requirements
Oct. 5, 2023
Based on the 2023 NEC.
Question: True or false? A 3 ft length of ¾ in. stainless steel flexible metal conduit enclosing conductors of a 20A circuit is permitted to serve as an equipment grounding conductor.
See answer below.
Answer: False
Explanation: A new requirement was added to Sec. 250.118(A)(5)(f) that requires a wire-type equipment rounding conductor for stainless steel FMC. This is due to the higher resistance of stainless steel.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
