© May1985 | Dreamstime.com
Dreamstime L 145295385 649dc985e11bc
Code Quiz: Surge Protection Devices for Dwelling Units
July 6, 2023
Based on the 2023 NEC.
Question: True or false? Dwelling units require surge protection devices.
See answer below.
Answer: True
Explanation: The requirement for surge protection at dwelling units was added to the 2020 NEC in Sec. 230.67 for all services supplying dwelling units. The 2023 NEC expanded those requirements to include dormitory units, guest rooms and guest suites of hotels and motels, and areas of nursing homes and limited-care facilities used exclusively as patient sleeping rooms. Requirements for surge protection were also added to Sec. 215.18 and Sec. 225.42 for any of these same locations that are supplied by a feeder.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
