© Andrii Yalanskyi | Dreamstime.com
Photo 164333240 Andrii Yalanskyi Dreamstime 6440463d606de
Code Quiz: GFCI Protection for a Receptacle Supplying a Fixed or Stationary Appliance
April 20, 2023
Based on the 2023 NEC.
Question: In other than dwelling units, a receptacle supplying a fixed or stationary appliance requires GFCI protection in which of the following situations?
  1. The receptacle is located within 6 ft of the sink
  2. The appliance is located within 6 ft of the sink
See answer below.
Answer: Both A & B
Explanation: Section 210.8(B)(7) now requires GFCI protection for receptacles that supply fixed or stationary appliances when either the receptacle or the appliance is located within 6 ft of the sink. It does not matter if the receptacle is accessible or not. A fault within the appliance can cause a shock hazard to someone contacting the appliance and the sink, therefore GFCI protection is now required.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 2595260 © Crystal Craig | Dreamstime.com
dreamstime_xl_2595260
ID 118474400 © Welcomia | Dreamstime.com
dreamstime_118474400
ID 6510117 © Sallyjogary | Dreamstime.com
dreamstime_xl_6510117
