© Sergii Gnatiuk | Dreamstime.com
Photo 164352387 Sergii Gnatiuk Dreamstime 63b6fbf2ce0b0
Code Quiz: Marking Disconnect Switches
Jan. 5, 2023
Based on the 2020 NEC.
Question: True or False? All disconnect switches must be marked to indicate their purpose.
See answer below.
Answer: False
Explanation: Section 110.22 of the 2023 NEC requires a disconnect to be marked to indicate its purpose unless the disconnect is located and arranged so that its purpose is evident, such as located adjacent to the equipment it controls.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 155082438 © Angie Amil | Dreamstime.com
dreamstime_xl_155082438
ID 367200439 © Contributor Asia | Dreamstime.com
dreamstime_xl_367200439
ID 81540477 © Wavebreakmedia Ltd | Dreamstime.com
dreamstime_xl_81540477
