© Alexander Zhenzhirov | Dreamstime.com
Photo 144532832 Alexander Zhenzhirov Dreamstime 6387b9c82a700
Code Quiz: NEC Requirements for Raceways in Wet Locations
Dec. 1, 2022
Based on the 2020 NEC.
Question:  Is the interior of a PVC conduit installed surface mounted on the exterior wall of a building considered to be a wet location or a dry location?
See answer below.
Answer: Wet location
Explanation: Section 300.38 of the 2020 National Electrical Code specifies raceways installed in a wet location are considered wet locations. This includes the inside of the raceway as well.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 33565053 © Lawcain | Dreamstime.com
dreamstime_xl_33565053_1
ID 374330235 © Mschuppi | Dreamstime.com
dreamstime_xl_374330235
ID 219971504 © Julie Feinstein | Dreamstime.com
dreamstime_xl_219971504
