© Ahmet Yamak | Dreamstime.com
Photo 223092987 Ahmet Yamak Dreamstime 62fd124190d20
Code Quiz: Switchboard Wiring Requirements
Aug. 18, 2022
Based on the 2020 NEC.
Question: Does the wiring entering a switchboard need to enter in the same vertical section that contains the circuit breaker it is terminated on?
See answer below.
Answer: Yes
Explanation: Section 408.3(A)(2) of the NEC states, "Other than the required interconnections and control wiring, only those conductors that are intended for termination in a vertical section of a switchboard or switchgear shall be located in that section." There is one exception that allows conductors to travel horizontally through vertical sections if they are isolated from busbars by a barrier.
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 331482540 © Bekir Ugur | Dreamstime.com
dreamstime_xxl_331482540
ID 331513454 © Petr Goskov | Dreamstime.com
dreamstime_xxl_331513454
ID 321335940 © Weerapat Wattanapichayakul | Dreamstime.com
dreamstime_xxl_321335940
