© Evgeny Karandaev | Dreamstime.com
Photo 60115045 Evgeny Karandaev Dreamstime com 6272c50c79b2c
Code Quiz: Determining the Appropriate Conductor Ampacity
May 4, 2022
Based on the 2020 NEC.
Question: How do you determine the ampacity of the conductors serving a three-phase 480V motor?
See answer below.
Answer: By using the value given in Table 430.250
Explanation: Section 430.6(A)(1) of the 2020 NEC requires you to use the values shown in Table 430.250 instead of the value on the motor nameplate.
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
