Magnetic-Mcc/iStock/Getty Images Plus
Code Quiz: The Definition of Readily Accesible
May 8, 2019
A question to check your knowledge of a recent Code change.
Question: True or False? A panelboard located behind a locked door of an electrical closet is considered to be "Readily Accessible."
See the answer below.
Answer: True
Explanation: A change in the 2017 NEC to the definition of Accessible, Readily in Art. 100 added the word "other than keys" to make it clear that a key is not considered a tool. A new Informational Note was also added explaining the use of keys is a common practice to control who has access to electrical equipment.
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
