National Electrical Code logo
Code Quiz: Supporting Conductors in Vertical Raceways
March 28, 2019
Check your knowledge of the Code requirements regarding support for conductors in a raceway.
Question: What is the maximum length of a vertical run of conduit containing 500kcmil copper conductors that does not require supporting the individual conductors in the raceway?
  1. 10 ft
  2. 20 ft
  3. 30 ft
  4. 50 ft
See the answer below.
Answer: 50 ft
Explanation: Section 300.19(A) requires support of conductors in vertical raceways if the vertical rise exceeds the values shown in Table 300.19(A). Additional intermediate supports are required to limit supported conductor lengths to not greater than those values specified in Table 300.19(A).
John Lupacchino | Senior Design Engineer
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
