Code Quiz: Medium Voltage Cable Support
July 19, 2018
Check your knowledge of the Code and Type MV cable support
Type MV cables terminated in equipment or installed in pull boxes or vaults shall be secured and supported by metallic or nonmetallic supports suitable to withstand the weight by the use of cable ties _________ for securement and support; or other approved means, at intervals not exceeding 5 ft from terminations or a maximum of 6 ft between supports.
A) UV and wet location rated
B) red and black in color
C) listed and identified
D) orange and blue in color
See the answer below.
Answer: C
As specifically outlined in a new requirement in the 2017 NEC [Sec. 328.30], “Type MV cable terminated in equipment or installed in pull boxes or vaults shall be secured and supported by metallic or nonmetallic supports suitable to withstand the weight by cable ties listed and identified for securement and support, or other approved means, at intervals not exceeding 5 ft from terminations or a maximum of 6 ft between supports.”
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
