Code Quiz: Field Marking of Equipment
Nov. 17, 2016
NEC requirements for field marking of equipment
The 2017 requirement for field marking of available fault current at service equipment rated 1,200A or more, installed in other than dwelling units, now includes which additional piece of information?
A) the date the fault-current calculation was performed
B) the field marking shall be of sufficient durability to withstand the environment involved
C) the field marking shall be legibly marked in the field with the maximum fault current
D) the calculation shall documented and made available to those authorized to design, install  inspect, maintain, or operate the system
Answer: D
Section 110.24(A) of the 2017 NEC has added an additional requirement for the available fault-current calculation to be documented and made available to those authorized to design, install  inspect, maintain, or operate the system.
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
