Code Quiz: Vertical Support Requirements for Cable Routing Assemblies
March 26, 2015
NEC rules on installing communication wires and cables in cable routing assemblies in vertical runs
Fill in the blank with the appropriate answer.
When installing communication wires and cables in cable routing assemblies, vertical runs of the cable routing assemblies shall be supported at intervals not to exceed _______, unless listed for other support intervals, and shall not have more than one joint between supports
A)  2 ft
B)  3 ft
C)  4 ft
D)  10 ft
Answer: C
The installation methods of communications circuits installed within buildings are outlined in Part V of Art. 800. As noted in Sec. 800.110(C)(2), when installing communication wires and cables in cable routing assemblies in vertical runs, supports shall be installed at intervals not to exceed 4 feet, unless listed for other support intervals, and shall not have more than one joint between supports.
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
