Code Quiz
Sept. 4, 2008
According to the 2008 National Electrical Code, electric drinking fountains installed in public buildings, such as schools, must meet which of the following requirements
Q. According to the 2008 National Electrical Code, electric drinking fountains installed in public buildings, such as schools, must meet which of the following requirements:
  1. Offer GFCI protection for personnel — Class A, 5mA (nominal) trip
  2. Can't be supplied with a hermetic compressor
  3. Offer GFCI protection only if it is located within 6 feet of a 15A or 20A, 125V single-phase receptacle outlet
  4. Offer GFPE protection — Class C, 30mA trip
  5. none of the above
Answer: A
As per 422.1 and 422.52, ground-fault protection for personnel is required for electric drinking fountains. This requirement is not limited to cord-and-plug connected appliances, but also applies to direct-wired electric drinking fountains. It's important to note that phase and voltage are not specifically addressed in this new requirement. In other words, this rule does not specifically indicate an applied voltage of 125V, single-phase.
Latest from Quizzes
ID 25002905 © Samiylenko | Dreamstime.com
dreamstime_xl_25002905
ID 367959703 © Suphachai Panyacharoen | Dreamstime.com
dreamstime_xl_367959703
ID 2075878 © Ivan Hafizov | Dreamstime.com
dreamstime_xl_2075878
