ID 127214904 © Mohd Hafiez Mohd Razali | Dreamstime.com
Courtesy ofwww.MikeHolt.com
Q. What is the Code rule for neutral connection bonding of a portable or vehicle-mounted generator?
See answer below.
A. Section 250.34(C) Neutral Conductor Bonding. The generator manufacturer is required to bond the neutral conductor to the generator frame where the generator is a component of a separately derived system.
Informational Note: For grounding portable generators supplying fixed wiring systems, see Sec. 250.30.
These materials are provided to us by Mike Holt Enterprises in Leesburg, Fla. To view Code training materials offered by this company, visit www.mikeholt.com/code.
