Interconnected Electrical Power Production Sources 5f049be943660
NEC Requirements for Interconnected Electrical Power Production Sources
July 7, 2020
Key takeaways from Art. 705
If an electric power production source (EPPS) operates in parallel with the primary source of electricity, it is an interconnected EEPS and must comply with Art. 705 of the National Electrical Code (NEC).
A photovoltaic system [690] that is the sole power source for specific branch circuits is not an interconnected EPPS. However, if that system is tied to the same service as the primary power source, then it is an interconnected EPPS.
Some highlights include:
  • A permanent plaque or directory at each service equipment location must denote the location of each power source [705.10].
  • An EPPS connected on the supply side [705.11] has different requirements than one connected on the load side 705.12]. For example, a supply side connected EPPS must meet the ground fault protection requirements of 230.95 while one on the load side does not.
  • The output of an EPPS must be compatible with the voltage, wave shape, and frequency of the system it’s connected to. This has implications for synchronous generators [705.14].
  • The rules for the source disconnecting means have been heavily revised with the 2020 NEC [705.16].
