Municipal, state, federal or other codes require, by law, systems to automatically supply power to certain loads if the normal power source fails (other than those classed as Emergency Systems, see Article 700). Any governmental agency having jurisdiction can also require a given facility to have such a system [701.2].
Article 701 of the National Electrical Code (NEC) provides the requirements for installation, operation, and maintenance of these systems. The requirements are similar to those for emergency systems. Some highlights include:
- Specific testing and maintenance requirements must be met [701.3]. For example, it must be tested periodically on a schedule and in a manner approved by the AHJ.
- The system must be able to support the entire designated load. A common strategy is the implementation of automatic selective load pickup and load shedding [701.4(C)].
- Transfer equipment must be automatic. It must be listed and marked for legally required standby use [701.5(A)].
- The circuits don’t have to be specially marked, but a sign must be placed at the service entrance indicating the type and location of each on-site legally required standby power source [701.7].
