The requirements for photovoltaic (PV) system wiring methods underwent extensive revision with the 2020 National Electrical Code (NEC) revision cycle. You can expect at least another round of heavy revision, because these systems are becoming increasingly affordable and thus increasingly ubiquitous.
As a benchmark, China identified numerous large metroplex cities where the cost of power from solar was on par with the cost of power from the grid. In the United States, progress has not been quite as rapid, but it is continuing. It won't be long until solar is commonly more affordable than normal grid power and/or normal grid power has a large solar component.
Labeling is a key area that was stressed this time around. For example, DC circuit conductors must be identified at all termination, connection, and splice points [Sec. 690.31(B)(1)]. In addition, there are special labeling requirements for wiring methods and enclosures that contain the DC conductors [Sec. 690.31(D)(3)].
With so many things needing to be identified and with the identification having to meet strict and detailed requirements, neatly installing a Code-compliant solar power system means using a professional-grade label making tool.
