© Rafael Henrique | Dreamstime.com
Dreamstime M 194405663 61572594e68c6
DOL Cites Houston Transmission Line Contractor for Safety Violations
Oct. 1, 2021
Mesa Line Services failed to attach personnel platform to crane properly.
One electrical construction worker died and another suffered severe injuries after falling about 15 stories from a platform that federal inspectors found was not secured properly to the crane suspending it. The employees were erecting electrical transmission lines near Houston.
A U.S. Department of Labor Occupational Safety and Health Administration investigation determined Mesa Line Services LLC failed to secure the personnel platform to the jib of the crane as required, and took minimal steps to reconfigure the crane for use as an aerial lift. OSHA also identified several deficiencies in how the platform was attached to the crane's jib.
OSHA cited Mesa for seven serious violations, including failing to follow manufacturer procedures when using a crane as an aerial lift, exceeding the rated capacity of a personnel platform and failing to secure the personnel platform to the jib assembly. The company faces $95,571 in proposed penalties.
“One life was lost and another worker is suffering needlessly from an incident that could have been prevented if the employer had followed required safety standards,” said OSHA Area Director Mark Briggs in Houston.
Headquartered in Houston, Mesa Line Services LLC provides electric construction contracting and other services. It is part of the Entregado Group, an investment platform of utility infrastructure executives and entrepreneurs focused on the utility and industrial infrastructure services sector, building, maintaining and restoring critical infrastructure for the transmission and distribution of electric power, telecommunications infrastructure for data transmission and communications, and critical utility services.
The company has 15 business days from receipt of citations and penalties to comply, request an informal conference with OSHA's area director, or contest the findings before the independent Occupational Safety and Health Review Commission.
Learn more about cranes and derricks in construction.
Latest from Accidents & Investigations
Homeinspectioninsider.com
electrical_panel
Photo 34435312 © Steve Allen | Dreamstime.com
Photo 110841691 © Paul Brady | Dreamstime.com
