Code Quiz: Conductors in Luminaire Outlet Boxes
Nov. 19, 2015
NEC guidelines on the temperature limit of conductors installed in luminaire outlet boxes.
What, if any, is the temperature limit of conductors installed in luminaire outlet boxes?
A) 60°C
B) 75°C
C) 90°C
D) Conductors shall not be subjected to temperatures greater than that for which they are rated.
Answer: D
As outlined in the first paragraph of Sec. 410.21, “Luminaires shall be of such construction or installed so that the conductors in outlet boxes shall not be subjected to temperatures greater than that for which the conductors are rated.”
Latest from Quizzes
ID 13299718 © Photocritical | Dreamstime.com
dreamstime_xxl_13299718
ID 353276645 © Contributor Asia | Dreamstime.com
dreamstime_xxl_353276645
ID 188713012 © Ivan Serebryannikov | Dreamstime.com
dreamstime_xxl_188713012
