© Kemaltaner | Dreamstime.com
Dreamstime M 23026488 61e98895d11f0
How Does Your Job Impact the Company?
Jan. 26, 2020
Why field data is priceless information to predict job-site productivity
Wouldn’t you like to have everything about your projects — such as accounting, purchasing, estimating, and actual job progress information — readily available to you anytime and everywhere? Of course, you would.
Accounting data is driven by business and legal requirements and provides a look into the past. While it can show you what has happened, it provides no insight into the future. When is the last time accounting closed your books before the end of the period? There are many things that you need to know about your business while there is still time to act and impact the results. For example:
  • Are the billings up to date and accurate?
  • Are all the change orders captured, approved, completed, and invoiced within the terms of your contract?
  • Is your composite rate rising or falling? Is it managed and controlled?
  • Do you have a handle on your receivables? Are they rising or falling next week or next month?
Field data is priceless information. This otherwise invisible information can predict the productivity of the job, and, more importantly, what’s adversely impacting productivity. When combined with accounting and estimation data, field information can provide the only complete picture of current project performance and reliably project future outcomes.
Field data is often omitted from business management decisions because it is difficult to gather and often requires observation and intuition to correctly interpret. Field data is often confused with subjective statements or simple opinions. But there is a difference, and correct data is essential. Reliable field data must be collected with respect to an established and objective baseline. Understanding and effectively using field data is only possible when organized with a consistent and objective method for categorization.
Effective project management requires deliberate usage of all data (separate and combined) at the time it is current and accurate. Consider the value of asking these questions:
  • Was the team able to get done what it planned for today? If not, why?
  • Did the team have the materials they needed? If not, why?
  • Is the team prepared with the tools and materials they need tomorrow? The next day?
  • Did the team have the manpower they needed? If not, why?
  • Is there a manpower plan for tomorrow? The next day?
  • Is all the completed work fully reflected in the billing?
  • Do you have sufficient supporting documentation to collect what’s billed?
Much like field data, estimating data is also very often underused and misunderstood. Estimation data is more than what you are estimating currently. Your estimating data cannot be limited to only material counts and “average” labor units. Ask yourself these questions:
  • Are we productive on this type of work, and do we have the correct knowledge and experience to profitably deliver the scope contracted?
  • Do we have the correct manpower plan and resources to take on this work?
  • Is our existing backlog and pipeline capable of supporting the future of the company?
  • Have our value engineering efforts considered all reasonable prefabrication and vendor services that could, should, and will be used?
Having data from all three sources (field, accounting, and estimation data) gets you to the starting line. But data alone is not useful for project management and effective project delivery. The tools for converting data into information are essential for the proper connectivity of all three sources, providing project managers with the information they need to use their skills and experience effectively.
Project management is dependent on properly connected data and creating a common form of accurate and reliable information. Raw data is not actionable by project managers; it needs to be categorized and prioritized from discrete events to become manageable information. Accurate information is actionable. Skilled project managers can use digitized project information to make very quick and knowledgeable decisions with inherently reduced risk. This is all working within the project delivery system — and what makes the project delivery system both repeatable and scalable with a growing business.
For a full picture of what is happening on a project, it’s key to triangulate between what we call The Three Databases: Field Data, Accounting Data, and Estimating Data. The Figure shows the linkage between the three databases and the information that can be shared between each for fully understanding impacts on your jobs. Note that this is not a technology concern; it is a process concern.
It’s important to recognize that the process of gathering and using the information should enhance your business results. Are the right items in place in your organization to capture and interconnect this information for your use in a timely and useful way? Unless you have included a process with defined categorization and analysis methods and techniques, standardized digitization, and thorough connectivity, then you do not have the right items in place for effective project management. What you do have are results based on a few good people on a few good projects, looking for a few lucky breaks — and betting your money on finding them.
When the business has accurate information fed to an effective project delivery system, then, over time, knowledge about the outcome and results can be captured and analyzed, forming a common and powerful feedback mechanism. At the overall company level, this common feedback allows the leadership and estimating teams to make very effective and knowledgeable strategic decisions about the projects available in their market. Analyzing each future project available with historical project information can help you understand which projects your company can make money on, which projects are worth investing limited business resources in, and which projects can secure (not jeopardize) the future of the business.
Everyone knows knowledge is power. Being able to quickly refer to and manage the connectivity of your job data, your accounting data, and your estimating data (including your pipeline and backlog) lets you see the full picture of what is happening around you today and what is going to happen in the future.
Phil Nimmo is vice president of business development at MCA, Inc., Grand Blanc, Mich. He can be reached at [email protected]. Jennifer Daneshgari is vice president of financial services and operations at MCA, Inc., Grand Blanc, Mich. She can be reached at [email protected].
Phil Nimmo, MCA, Inc.
Phil Nimmo is vice president of business development at MCA, Inc. He can be reached at [email protected].
Jennifer Daneshgari
Jennifer Daneshgari is the vice president of financial services at MCA, Inc. She can be reached at [email protected].
Latest from Business Management
ID 335485132 © Imaginiac . | Dreamstime.com
The Top 5 Electrical and Construction Industry Trends for 2025
In the typical facility, the plant manager has X amount of discretionary spending power that can be directed toward a single purchase. At each level of management down, discretionary spending is stepped down into smaller amounts. Anything beyond a given manager’s limit must be appealed to the next level up. For example, the Plant Engineer can’t quite swing a purchase of $5200 but the Plant Manager can approve it. This informal arrangement reduces corporate overhead and improves operational efficiency. It does not address whether the spending decisions would make financial sense to the Chief Financial Officer, but the cap at each level keeps any mistakes to a reasonably acceptable loss or misallocation of resources. Beyond the Plant Manager’s limit, there is usually a formal process for getting spending approval. It typically involves filling out a Capital Request (or similarly named form). In well-run companies, the form is very structured. It mostly wants some basic information that will give the reviewer(s) the ability to justify not just the purchase but also the cost of acquiring the capital to do so. Because the funds will typically be borrowed by the corporation, the cost of capital must be balanced against the return on investment. There will be at least one person crunching the numbers to make what is called “the business case” for the proposed spending. Making the business case is something you should do, in some way or another, when considering spending within your approved limits. If the spending is above your approved limits, then the manager above you will need a bit beefier of a business case. The business case must take into account the value obtained versus the money spent. Consider the purchase of a thermographic camera. If you intend to purchase a mid-range camera but nobody at your facility is trained and certified in its use, the purchase is probably a waste of money. You’d be better off getting an entry-level camera and then arranging for a path toward certification if you intend to have that ability in-house and it makes operational and financial sense to do so. And generally, it makes sense to have a person or two with Level I certification so they really understand how to get the most out of a camera system that’s beyond the basic level. On the other hand, if you were a manager at an electrical testing firm with several Level III Thermographers you would be wasting your thermographers if you decided to “save money” by equipping them with only basic or even intermediate camera systems. Your firm needs to be able to troubleshoot problems when that important client calls in a panic. Your thermographers need the tools to do that job, and “cost-saving” on camera systems won’t cut it. Presumably, your clients are smart enough to already have basic camera systems; they just don’t have the expertise to use advanced systems. Sometimes a different logic applies to other types of test equipment. In the typical plant, maintenance electricians need sophisticated DMMs. If they lack the training to use the features that are needed for most effectively keeping equipment running, simply choosing a less capable DMM they already know how to use is not the answer. They need the appropriate DMM along with the training on how to use those features correctly. So far, we haven’t looked at the need to crunch any numbers to make the business case. What we have done is think about the match between the purchase, the problem that needs to be solved, and the ability of the user to solve the problem using that purchase. This sounds like a common sense approach that everyone would naturally take, but people often lose sight of the reason for the purchase in the first place. The tendency is to either go all out on something they can’t use or don’t need, or to “save money” by shortchanging the end users with something that doesn’t allow them to do what they need to do. What about those numbers? When you do a purchase request, a bean counter is going to try to determine the cash flows involved (typically in monthly periods). If you write something like, “The payback period is three years,” they don’t find that helpful. Lenders care that a loan can be serviced, and cash flow is the critical factor in calculating whether it can. Thus, beancounters don’t use payback to determine whether they can afford to borrow. They use the Internal Rate of Return (IRR) or Modified Internal Rate of Return (MIRR). Formulas for both IRR and MIRR have been in spreadsheet programs for over two decades, but before that they were determined using a Business Math Calculator (about $150 in 1990). And before that, they were laboriously calculated by hand. The cash flows that are charted will be either additional revenue generated or losses prevented. To help the person who figuratively wears the green eye shade, tie the use of the test equipment to a revenue stream. A major appliance plant in Tennessee has several production lines that collectively produce $1,560,000 per hour of revenue. Thus each minute of unplanned downtime is quite costly. If the plant electrical engineer there wanted to upgrade test equipment in a way that exceeds the Plant Manager’s spending authority, he needs to help the green eye shade guy do the math. He can cite short case histories from the past two years and briefly explain how having X capability (present in the new equipment, absent in the existing equipment) would have saved Y minutes of downtime (which the green eye shade guy will calculate out in terms of revenue and cash flow). The green eye shade guy also needs to know whether each case history is a one-off that will never recur or if it’s representative of what to expect in the future. You can settle this question with a brief explanation. For example, “The responding technician did not have a [name of test equipment]. Consequently, he had to arrive at the same conclusion by other means to the tune of 24 minutes of downtime he would not have incurred if he’d had a [name of test equipment]. This problem occurred once on Line 2 and twice on Line 4.” Now the green eye shade guy can simply add up the downtime, monetize it, and create the cash flow analysis. And it’s really good for something like a power monitor. For example, “In this particular case the plant did not have a monitoring system capable of detecting short-term bursts of power, which we call transient spikes, and alerting us. Transients happen with no notice, and usually without being detected. The motor shop forensic report shows the main motor failed due to winding insulation failure caused by transients. With a power monitor detecting and reporting those transients, we would have been able to intervene before outright failure, on a scheduled basis. That would have reduced downtime by 57 minutes twice last year alone.” Making the business case for your smaller purchases means simply thinking about what you are trying to accomplish and then making sure you are spending the funds correctly to achieve that goal. But as you go up the food chain, you need to make the picture more clear. And when you appeal to corporate for approval, you need to provide reasonably accurate downtime savings numbers that can be converted by them to revenue loss prevention in specific dollar amounts.
Man staring at wall with hand-drawn question marks and money bags on it
