Gerald Talbot Promo 5f76377d65bb0
Help Your Residential Electrical Contracting Business “Fall” into Place
Oct. 5, 2020
Seven tips to ensure your company stays strong and healthy during the autumn months
As the temperature begins to fall, so does revenue and call volume. Hopefully, your residential electrical contracting business enjoyed a successful summer season. Despite all the turmoil going on around us these days, many of our businesses have continued to perform well. Making strides forward is great, but if you end up giving all your summer profit away in the colder months, then what was the point of all your hard work? Throw a presidential election, global pandemic, and uncertain financial markets into the mix, and navigating the next few months is enough to make your head spin.
First, we must identify what is certain and what is not. Events happening across the country, severe and unpredictable weather, and people’s perceived needs are all difficult to determine. Although we are not mind readers, we are not powerless either. It is important to consider every possible way your residential electrical contracting business can thrive in the coming months versus everything that is working against its success. Below are some tips to consider when trying to make the autumn months fall into place.
  1. Take advantage of the slower pace to pursue training opportunities with your techs. Coming off the high of summer means they may need to push the reset button on their sales process.
  2. Consider pulling out some season-appropriate creativity for your next marketing campaign. This can help get the phone ringing during the downturn in calls.
  3.  Stock up on inventory and planning your slow-time marketing. January and February are typically downtimes for electrical contractors in the service industry.
  4.  Start rehashing estimates given to customers in the past month or two. You never know unless you ask. Perhaps there was a change in circumstances for the client. A previous “no” might become a “yes.”
  5. Concentrate on refining your skills as a manager/owner. Don’t forget to touch base with your technicians on quality of work and warranty issues that may make them better electricians. Look at areas of connections, panel neatness, twist radius of pigtails, sealant of outdoor fixtures, and electrical boxes.
  6.  Check in with your clients. A lot of events can happen during the summer months that may leave clients feeling neglected. This is a common challenge during peak season. Make sure your customers know you are thinking about them and that you value them. A happy client may tell a few people about your service, but an angry one will certainly tell everyone in their circle of influence.
  7. Replace your technicians’ uniforms. Uniforms inevitably take a beating in the peak months. Purchase new ones and present neat and newly dressed technicians in the fall. As I have said before, you never get a second chance to make a first impression.
It’s no secret that seasons change, bringing new challenges and hurdles. How you prepare and respond to these challenges will determine your overall success. Make time to evaluate your business and prepare for the next few uncertain months.
Talbot is a licensed, master electrician in Georgia, where he was born and raised. He has been in the industry for 19 years and is currently the operations manager for Mister Sparky Atlanta, where he oversees a team of technicians. In his spare time, he plays with his kids, volunteers, and enjoys flipping houses. He can be reached at [email protected].
Gerald Talbot | Operations Manager
Gerald is a licensed, master electrician in Georgia, where he was born and raised. He has been in the industry for 17 years and is currently the operations manager for Mister Sparky Atlanta, where he manages a team of technicians.
Latest from Business Management
ID 335485132 © Imaginiac . | Dreamstime.com
The Top 5 Electrical and Construction Industry Trends for 2025
In the typical facility, the plant manager has X amount of discretionary spending power that can be directed toward a single purchase. At each level of management down, discretionary spending is stepped down into smaller amounts. Anything beyond a given manager’s limit must be appealed to the next level up. For example, the Plant Engineer can’t quite swing a purchase of $5200 but the Plant Manager can approve it. This informal arrangement reduces corporate overhead and improves operational efficiency. It does not address whether the spending decisions would make financial sense to the Chief Financial Officer, but the cap at each level keeps any mistakes to a reasonably acceptable loss or misallocation of resources. Beyond the Plant Manager’s limit, there is usually a formal process for getting spending approval. It typically involves filling out a Capital Request (or similarly named form). In well-run companies, the form is very structured. It mostly wants some basic information that will give the reviewer(s) the ability to justify not just the purchase but also the cost of acquiring the capital to do so. Because the funds will typically be borrowed by the corporation, the cost of capital must be balanced against the return on investment. There will be at least one person crunching the numbers to make what is called “the business case” for the proposed spending. Making the business case is something you should do, in some way or another, when considering spending within your approved limits. If the spending is above your approved limits, then the manager above you will need a bit beefier of a business case. The business case must take into account the value obtained versus the money spent. Consider the purchase of a thermographic camera. If you intend to purchase a mid-range camera but nobody at your facility is trained and certified in its use, the purchase is probably a waste of money. You’d be better off getting an entry-level camera and then arranging for a path toward certification if you intend to have that ability in-house and it makes operational and financial sense to do so. And generally, it makes sense to have a person or two with Level I certification so they really understand how to get the most out of a camera system that’s beyond the basic level. On the other hand, if you were a manager at an electrical testing firm with several Level III Thermographers you would be wasting your thermographers if you decided to “save money” by equipping them with only basic or even intermediate camera systems. Your firm needs to be able to troubleshoot problems when that important client calls in a panic. Your thermographers need the tools to do that job, and “cost-saving” on camera systems won’t cut it. Presumably, your clients are smart enough to already have basic camera systems; they just don’t have the expertise to use advanced systems. Sometimes a different logic applies to other types of test equipment. In the typical plant, maintenance electricians need sophisticated DMMs. If they lack the training to use the features that are needed for most effectively keeping equipment running, simply choosing a less capable DMM they already know how to use is not the answer. They need the appropriate DMM along with the training on how to use those features correctly. So far, we haven’t looked at the need to crunch any numbers to make the business case. What we have done is think about the match between the purchase, the problem that needs to be solved, and the ability of the user to solve the problem using that purchase. This sounds like a common sense approach that everyone would naturally take, but people often lose sight of the reason for the purchase in the first place. The tendency is to either go all out on something they can’t use or don’t need, or to “save money” by shortchanging the end users with something that doesn’t allow them to do what they need to do. What about those numbers? When you do a purchase request, a bean counter is going to try to determine the cash flows involved (typically in monthly periods). If you write something like, “The payback period is three years,” they don’t find that helpful. Lenders care that a loan can be serviced, and cash flow is the critical factor in calculating whether it can. Thus, beancounters don’t use payback to determine whether they can afford to borrow. They use the Internal Rate of Return (IRR) or Modified Internal Rate of Return (MIRR). Formulas for both IRR and MIRR have been in spreadsheet programs for over two decades, but before that they were determined using a Business Math Calculator (about $150 in 1990). And before that, they were laboriously calculated by hand. The cash flows that are charted will be either additional revenue generated or losses prevented. To help the person who figuratively wears the green eye shade, tie the use of the test equipment to a revenue stream. A major appliance plant in Tennessee has several production lines that collectively produce $1,560,000 per hour of revenue. Thus each minute of unplanned downtime is quite costly. If the plant electrical engineer there wanted to upgrade test equipment in a way that exceeds the Plant Manager’s spending authority, he needs to help the green eye shade guy do the math. He can cite short case histories from the past two years and briefly explain how having X capability (present in the new equipment, absent in the existing equipment) would have saved Y minutes of downtime (which the green eye shade guy will calculate out in terms of revenue and cash flow). The green eye shade guy also needs to know whether each case history is a one-off that will never recur or if it’s representative of what to expect in the future. You can settle this question with a brief explanation. For example, “The responding technician did not have a [name of test equipment]. Consequently, he had to arrive at the same conclusion by other means to the tune of 24 minutes of downtime he would not have incurred if he’d had a [name of test equipment]. This problem occurred once on Line 2 and twice on Line 4.” Now the green eye shade guy can simply add up the downtime, monetize it, and create the cash flow analysis. And it’s really good for something like a power monitor. For example, “In this particular case the plant did not have a monitoring system capable of detecting short-term bursts of power, which we call transient spikes, and alerting us. Transients happen with no notice, and usually without being detected. The motor shop forensic report shows the main motor failed due to winding insulation failure caused by transients. With a power monitor detecting and reporting those transients, we would have been able to intervene before outright failure, on a scheduled basis. That would have reduced downtime by 57 minutes twice last year alone.” Making the business case for your smaller purchases means simply thinking about what you are trying to accomplish and then making sure you are spending the funds correctly to achieve that goal. But as you go up the food chain, you need to make the picture more clear. And when you appeal to corporate for approval, you need to provide reasonably accurate downtime savings numbers that can be converted by them to revenue loss prevention in specific dollar amounts.
Man staring at wall with hand-drawn question marks and money bags on it
