Pti Small Variables Can Cause High Risk Pr Image 5 24 21 60ba477a36b57
Small Variables Can Cause High Risk in Power Tools
June 10, 2021
Industry organization strongly discourages use of third-party batteries
While it’s true that a properly cared-for power tool should provide years of trouble-free service, the key phrase is “properly cared for.” Because, in truth, the internals of power tools contain delicately balanced systems that can quickly turn dangerous if caution is not given. The Power Tool Institute recently warned users that even the smallest variable, such as introduction of a third-party battery, can substantially increase the risk of tool failure, fire damage, and even personal injury.
At the heart of the power tool system is the relationship between the tool, its battery, and the battery charger. Each manufacturer has its own unique control circuitry that allows the system to communicate properly. This is what controls critical functions, such as cell balance, energy levels, flow of energy in/out, and temperatures. According to the Power Tool Institute, it’s likely that third-party batteries will not be compatible with the energy demands of the system. In fact, in a recent press release, the organization stated, “Introducing a third-party, knock-off, or counterfeit battery can choke off system communication. Without the system’s ability to communicate during use, tool operators run the risk of lower performance and a shorter life from the tool. The third-party battery can also overheat, reducing its life or even causing complete failure. In the worst-case scenario, a knock-off battery can cause the tool’s motor to burn up if it starves or pushes too much current through it. These batteries can catch fire on the charger (and have) when cell temperatures aren’t being properly monitored and managed.”
The original manufacturers’ batteries use cells with proven designs, strict quality control, and longer-lasting capacity. For more information from the Power Tool Institute on safe usage of power tool batteries, visit its website.
Latest from Construction
