Power Quality Analyzer
Dec. 1, 2003
Power quality analyzer The WM3-96 power quality analyzer measures and controls several power quality parameters like TRMS measurement of THD, harmonic analysis to the 50th harmonic, voltage, current, and demand. The analyzer includes a 32-bit microprocessor encased in a 96 mm x 96 mm housing and displays measurements on a LCD. It can also use Modbus-RTU protocol for monitoring as many as 255 individual
The WM3-96 power quality analyzer measures and controls several power quality parameters like TRMS measurement of THD, harmonic analysis to the 50th harmonic, voltage, current, and demand. The analyzer includes a 32-bit microprocessor encased in a 96 mm x 96 mm housing and displays measurements on a LCD. It can also use Modbus-RTU protocol for monitoring as many as 255 individual instruments when using Wattsoft3 software.
Carlo Gavazzi
For more information, visit https://www.gavazzionline.com/usaenergymn.htm.
